ive recently bought a blue flame cat back system and a night pager de-cat
the system arived 1st and came with 3 new bolts from cat to front pipe
then cat came with 3 bolts for the same flange ??
does it matter which bolts i use as the bolts look diff and one set has washers and other doesnt
cheers
driver
i have 2 totally diff erant sets, a set came with decat and a set came with exhaust, just making sure that theres nbo reason i shunt use 1 set lol
ill use washer set anyway
cheers
washers are always better.
As far as the bolts go, on top of the bolt there should be a number, the higher the number, the stronger the bolt.
Not that it will need to be really strong, but I would take the ones with the highest numbers on it.
If there arn't any numbers on it, there won't be much difference, just take the shiniest ones <_<
