Tommy_G Posted June 26, 2008 Posted June 26, 2008 · Remove dials from car, ie: remove surround, unclip Speedo mechanism, and the three plugs.Do the following on both sets of dials· Unclip the bottom clips, making sure they are the black ones and not the clear ones.· If the dials keep closing, use a screwdriver to keep the bottom apart while unclipping the top ones.· Unscrew the two large gold screws, these are the ones surrounding the Speedo mechanism.· Unscrew the two smaller silver screws to the right if them (see pic)· Carefully remove needle, I found using a screwdriver was easiest (be careful not to scratch the dial though.)· Undo the two screws closest to the centre (the only two screws�lol)· Pull the dial away from the odometer.· Swap the odometer to the other dial and screw it all back together and your done.· Check that the Speedo needle is correct by letting it rest, it must rest a 0 (sort of obvious but easily forgotten)Tips:· Be careful not to accidentally change the position of the Speedo needle.· It may be a good idea to wear gloves, as some marks were left by my fingers · Finally it may be a good idea at this time to adjust the fuel gauge Quote
