muthaducka Posted June 29, 2008 Share Posted June 29, 2008 Hi GuysI've bought a set of celica GT4 calipers and I'm having difficulty fitting them to my ep82. The spacing is about 3/4mm out of where i need it to be. I cannot move the caliper backwards so need to move the disk forwards to get the right setup. If I move the disk forward, the stud bolts are not long enough for a secure fit (3 turns max).I've got some new longer stud bolts and tried drilling out the existing stud bolts. What a nightmare. The metal is very hard and even with a new set of drills it's taken a couple of hours to get close to getting just one drilled out. There must be an easier way. I've just tried to remove the plate with the 4 stud bolts attached but the nut turns with the axle so I can't get any leverage. I lowered one side of my car to the ground with the wheel attached to keep one side still and but it still turns (I'm sure that's not good).Please help!!!! Quote Link to post Share on other sites
muthaducka Posted June 29, 2008 Author Share Posted June 29, 2008 managed to get it sorted now, I got an answer on the gtt forum - knock the stud bolts out with a hammer! Quote Link to post Share on other sites
