jobyonekenobe Posted June 30, 2008 Posted June 30, 2008 hey all not sure if i have the right part for this problem and it will probably sound stupid but here goeswhen i turn right round corners or roundabouts the engine feels like its trying to stall and the rev counter drops about a thousand revs then comes back up. this only happens when i go right tonow i no your thinking you muppet your joking but i am serious.i have had new ht leads about four weeks ago and new plugs november last year with a full service.the car also has been plugged in to the computer and there are no recorded faults at all.any gueeses pleas help. Quote
DavidAshton Posted June 30, 2008 Posted June 30, 2008 Something to do with power steering? Its powered off the engine right? Actually my revs go up if im still and turn the wheel... so i have no idea. Quote
paul w Posted July 1, 2008 Posted July 1, 2008 Wire caught and shorting on that side as you turn the wheel. Quote
jobyonekenobe Posted July 4, 2008 Author Posted July 4, 2008 hey peepsright i have worked out the problem with the carwhen the stupid pig ignorant thick mentally retarded a.j services tried to fix the heater matrixthey unplugged the ecu and never plugged it back in properley so every time i hit a bump it would move then when i turned the corner it would unplug a bit.also that was the problem with the led boost gauge in the rev counter so its fixed.sadly i have been so busy working i have not been able to drive it since i got it back. Quote
