bought a gt ep82
if i have a fmic, fuel regulator, uprated actuator, new exhaust an de cat would i run it if its rolling roaded?
i'm new to tuning.
effectively what mods do i need to run 180 - 190 brake.
replies would be well appreciated.
cheers craig
with what you listed above plus a upgraded manifold. then you will need some way around the fuel cut, so fcd. also relocated filter to front. that should be about there. a hybrid turbo will make it easier to acheive.
but first brakes and suspension. i cant stress that enough.
^^^^^ totally what keirz said, before you decide to follow big power sort out the handling and breaking other wise all the hard work and money you spend will be laying upside down the other side of a hedge somewhere ;)
you should look into uprating brakes and handling before yah go giving her 180-190 horsies as standard they are not known for awesome handling or stopping. just a thought.
