Glanza Al Posted July 20, 2008 Share Posted July 20, 2008 Hi chaps, thought Id paint the plastic pulley cover on the side of the engine, I know its fixed with 4 bolts, but after removing them, it still wont budge ;), cany anyone point me in the right direction?Also, another thing is confuzzling me, the standard actuator has 2 terminals, one going to the turbo, and the other going to the thin metal pipe into the engine. Whereas the new HKS one only has one :s, which pipes do I need/not need and what can I remove?Any help is greatly appreciated ;)Alex. Quote Link to post Share on other sites
WallaceGlanza Posted July 20, 2008 Share Posted July 20, 2008 I think you need to take off the bottom pulley cover to get the top one of too, not 100% sure though.With the actuator you should have a t piece with the kit which you use to connect up all the original vaccum lines, or if you have a boost controller you just have two lines coming from it, one goes to the nipple on the turbo and the other to the actuator port. Quote Link to post Share on other sites
briggers Posted July 20, 2008 Share Posted July 20, 2008 good question as i will be getting one of those actuators soon. sorry i cant help tho Quote Link to post Share on other sites
briggers Posted July 20, 2008 Share Posted July 20, 2008 justa quick question what paint did you use to paint the rocker cover as i will be painting mine the same colour as im going with blue engine bay and red outside ie calipers rim lip and possibly colour the gt turbo sign on the door. Quote Link to post Share on other sites
Glanza Al Posted July 20, 2008 Author Share Posted July 20, 2008 Erm I did 3 coats of plastikote Hot paint (resistant to 750 degrees), then 3 coats of plastikote super enamel stuff. And thanks Wallace ;)Alex. Quote Link to post Share on other sites
briggers Posted July 20, 2008 Share Posted July 20, 2008 Erm I did 3 coats of plastikote Hot paint (resistant to 750 degrees), then 3 coats of plastikote super enamel stuff. And thanks Wallace ;) Alex.where did you get that from as i would only know halfords who do loads of spray paint but i know that stuff would be crap. ????????????????????????????????? Quote Link to post Share on other sites
Glanza Al Posted July 20, 2008 Author Share Posted July 20, 2008 Nope I got it from Halfrauds, they may sell it, but they sure as hell dont make it ;) Quote Link to post Share on other sites
briggers Posted July 20, 2008 Share Posted July 20, 2008 WHEN YOU TOOK THE ROCKER COVER OFF DID YOU HAVE TO REPLACE ANYTHING. Quote Link to post Share on other sites
ecksjay Posted July 20, 2008 Share Posted July 20, 2008 might be worth replacing the rocker cover gasket whilst you're there, saves it leaking at a later date doesn't it. Quote Link to post Share on other sites
Glanza Al Posted July 20, 2008 Author Share Posted July 20, 2008 what he said ^^ ;)Yeah rocker cover gasket, and I had to replace the PCV as I broke it taking the bastard thing out ;)Alex. Quote Link to post Share on other sites
Mikey Jay Posted July 20, 2008 Share Posted July 20, 2008 What's the PCV? Quote Link to post Share on other sites
briggers Posted July 20, 2008 Share Posted July 20, 2008 go up and look at the yellow pipe. thats the pcv valve i think from memmory but the bit entering the rocker cover . by the way sorry mate for hijacking your thread. just im going to be doing it soon and wanted that exact same colour Quote Link to post Share on other sites
