Does anybody know about this?
Hi chaps, thought Id paint the plastic pulley cover on the side of the engine, I know its fixed with 4 bolts, but after removing them, it still wont budge ;), cany anyone point me in the right direction?
Also, another thing is confuzzling me, the standard actuator has 2 terminals, one going to the turbo, and the other going to the thin metal pipe into the engine. Whereas the new HKS one only has one :s, which pipes do I need/not need and what can I remove?
Any help is greatly appreciated ;)
Alex.
I think you need to take off the bottom pulley cover to get the top one of too, not 100% sure though.
With the actuator you should have a t piece with the kit which you use to connect up all the original vaccum lines, or if you have a boost controller you just have two lines coming from it, one goes to the nipple on the turbo and the other to the actuator port.
justa quick question what paint did you use to paint the rocker cover as i will be painting mine the same colour as im going with blue engine bay and red outside ie calipers rim lip and possibly colour the gt turbo sign on the door.
  Glanza Al said:
Erm I did 3 coats of plastikote Hot paint (resistant to 750 degrees), then 3 coats of plastikote super enamel stuff. And thanks Wallace ;)
Alex.
where did you get that from as i would only know halfords who do loads of spray paint but i know that stuff would be crap. ?????????????????????????????????
go up and look at the yellow pipe. thats the pcv valve i think from memmory but the bit entering the rocker cover . by the way sorry mate for hijacking your thread. just im going to be doing it soon and wanted that exact same colour
