steviet Posted August 2, 2008 Posted August 2, 2008 I have just fitted my rolla manifold and having a bit of trouble with the throttle cable adjustment,cant get it right to have the cable set for full throttle opening when fitting the cable to the bracket on the manifold,Has anyone came across this?cheers stevie Quote
DavidAshton Posted August 2, 2008 Posted August 2, 2008 Yeah same issue i think, my acceclerator pedal had loads of play in it, its easier to sort it from the accelerator rather than the mainfoldhttp://www.ukstarletclub.com/forums/index....ic=8883&hl=This is the post i made when i had the problem, should help you out. Quote
steviet Posted August 3, 2008 Author Posted August 3, 2008 Did you have any problems with the manifold rattling about,cause theres no brace at the back of it? Quote
