Miller_Ep91 Posted August 12, 2008 Posted August 12, 2008 just wondering what springs give the best drop and ware to get them from??? ive got uprated shocks just need springs but wnt it as low as possible!!! also has anyone got spacers on or is it a bad idea? if u have ware did you get them from? thanks jonny. Quote
ecksjay Posted August 14, 2008 Posted August 14, 2008 beware if you drop it low then you WILL need a panhard rod if you dont have one already, otherwise it'll crab worse than a diseased hooker. Quote
scutch0 Posted August 14, 2008 Posted August 14, 2008 spacers are ok, but you should get the ones thathave the extended centrebore so you can still run spigot rings.i think sicaln has a set for his V and they were about 100 quid, you'll need longer studs too. Quote
Guest Enzo Posted August 14, 2008 Posted August 14, 2008 hubcentric spacers are the only way really, get them from a reputable company, and dropping, coilovers are the best option really Quote
Mikey Jay Posted August 15, 2008 Posted August 15, 2008 Do you still need hubcentric spacers if only spacing by a small amount by the way? Quote
Miller_Ep91 Posted August 15, 2008 Author Posted August 15, 2008 cheers for theat boys i will have a shop around. so what lowering springs are best for most impressive drop???? i have uprated shocks already as coilovers r a bit 2 much for my budget at the min. Quote
