my mate just got an ep. it had a recon engine fitted and gear box with aftermarket lsd. the car is lowerd. everything is fine when turning right. but does some noise when turning left. the guys was told that the car need to be lifted at the front because of the lsd. does that make anysense?
jack the car up at the front so both wheels are off the ground.
spin a wheel forward. if it has an lsd they will both spin forwards. if not the other one will spin backwards.
as for the noise while turning, LSDs can make a clonking noise, but id also check the CV to see if thats ok. and clicking while turning is a symptom that its on its way out.
and raising the front because its got an LSD? thats just someone speaking out of their arse. suspension height makes no difference to how an LSD works.
