Disco Stew Posted August 15, 2008 Posted August 15, 2008 Does anyone have a copy of the diagnostics codes for an ep91, i want to find out what my warining light means, so if i bridge the diagnostics connectors the engine management ecu will flash and relate to some data which will help me find out what is rong with my car!Please help!ThanksStew Quote
ToyotaTech15 Posted August 15, 2008 Posted August 15, 2008 is the engine a fte or just a 4efe cause i can get the 4efe ones from work 2moro if you want but i hink the fte ones will be different because of the turbo!!!!thanksGary Quote
Disco Stew Posted August 15, 2008 Author Posted August 15, 2008 is the engine a fte or just a 4efe cause i can get the 4efe ones from work 2moro if you want but i hink the fte ones will be different because of the turbo!!!!thanksGaryIts a glanza v so its the turbo, i think the 4fte engine im not sure, new to the starlet scene! Quote
ToyotaTech15 Posted August 15, 2008 Posted August 15, 2008 if its a glanza v itl be a 4efte, i can get you the diagnostic code chart for the 4efe non-turbo not saying for that it will be all correct!!i could PM you the chart if you wanti cant get the 4efte trouble codes as it was an import, maybe you could speak to sheekey as he works for toyota aswell, he might have it but im not sure!!thanksGary Quote
