Done a search but no luck on this.
Rear disc & pads come this morning for my 1998 Glanza, genuine parts.
I am trying to determine the difference between ABS and Non ABS on rear discs.
I am pretty certain my order is right but is there a way to physically tell a ABS disc to a Non ABS.
Also is there a write-up anywhere on changing rear discs and pads, already looked in 'braking' under technical section, no luck.
Thanks in advance.
  • 3 months later...
There is a ring gear/teeth on the inside of the disc that the ABS sensor picks up.
A non ABS disc will not have it, i believe you can knock the ring gear off and put it on the non abs disc, but dont hold me to this!!! better off getting the ABS ones in the first place....
<_<
