What size piping will i need? i plan to use the old rubber pipe which is attached to the filter box then have a pipe running to the bumper from the filter if it makes sense?
Im not sure what piping size you need. Go measure the throttlebody and get one that fits snuggly over that.
You also need the diameter of the Induction kit because you may need a reducer for it to fit on the pipe to the throttle body
