Hi, I got some problem with my car. When the car is neutral, there is some click click noise, but when I press the clutch, the wierd sound disappear. I have checked with a garage, they said there is nothing wrong. but i really wanna know where that sound come from. Do any of you has experience on this or has any clue?
Its the clutch release bearing.....mine did it when i got it after replacing the clutch and bearing it went away. The clutch that was in there was almost halfway through its life....dont worry about it (just dont sit there at the lights with at biting point of fully depressed)
  • 3 weeks later...
its just the gearbox turnin.u no wen its the bearing beacause it makes the noise wen the clutch is depreased. if it disapears when the clutch pedal is depresed its just the gearbox turnin and prob went after havin a new clutch fitted due to havin the correct oil level put in there
