BlackRocket Posted October 9, 2008 Share Posted October 9, 2008 Does anyone know which adapter I would need if any? from this linkebayI want to get this ordered asap so I can get it fitted when I get the car this weekend Quote Link to post Share on other sites
puma Posted October 9, 2008 Share Posted October 9, 2008 Does anyone know which adapter I would need if any? from this linkebayI want to get this ordered asap so I can get it fitted when I get the car this weekendwhen i fitted mine it came with a few rubber rings.remove the old air filter.then see which rings fit.pop it on (do not forget to put the censer in as well).tighten the new kit into place.can be a small bit fiddly but easy.also with mine to stop it moving and bouncing around i used two cable ties to keep it in place. Quote Link to post Share on other sites
BlackRocket Posted October 10, 2008 Author Share Posted October 10, 2008 when i fitted mine it came with a few rubber rings.remove the old air filter.then see which rings fit.pop it on (do not forget to put the censer in as well).tighten the new kit into place.can be a small bit fiddly but easy.also with mine to stop it moving and bouncing around i used two cable ties to keep it in place.Cheers Puma - I'll get it ordered then! Quote Link to post Share on other sites
