it should come with instructions but it will go from the turbo to the fmic and then from the fmic to the throttle boddie. its just a bit fiddly witht the starlet being a bit cramped.
It's not that hard mate, the tight 90degree bends are out of the cooler, the bit with the lil sticky up bit is from the throttlebody at the top (top of standard top mount) the bit with the flange comes off the top of turbo the rest just joins up to the other bits.
Somthing like this
