ChineseMafia Posted October 18, 2008 Share Posted October 18, 2008 hey guys i have a problem and i need some help first off im in the caribbean island os St lucia and parts for the starlet are not readly available so we do a lot of mixing and matching over here so heres the mix and match im after a friend gave me his t25 from his sylvia but i cant use it cause i have no manifold and to order a pre built one will be to expensive so i came up with this idea would it be possible to cut the flang off this http://cgi.ebay.com/ebaymotors/Toyota-Coro...emZ370097887101 and replafe with a 4efte flange . is the physical size of the 4age manifold that mucg bigger or smaller that the 4efte manifold ? or is there some other manifold i can get that is better for such a conversion ?really need some help on this one guys thanks Quote Link to post Share on other sites
ecksjay Posted October 18, 2008 Share Posted October 18, 2008 i believe the runners are quite a bit different mate, if you're gonna go to that much effort then you may aswell get a manifold custom made. Quote Link to post Share on other sites
ChineseMafia Posted October 18, 2008 Author Share Posted October 18, 2008 i believe the runners are quite a bit different mate, if you're gonna go to that much effort then you may aswell get a manifold custom made.custom where Quote Link to post Share on other sites
