first question is why is it hitting fuel cut. sloppy actuator? crud wastegate? both normal features with the stock ct9's.
if you were to fit an emanage and have it mapped, you may experience unwanted creep above and beyond what the unit is mapped for, which would be pointless and is what fuel cut is there for (i.e to protect the engine, even if it isn't very nice to experience).
you may find a decent electronic boost controller might cure the creep problem, but it differs from car to car.
.8 is too hi, try winding down the actuater a coupe of notches down to about .7 to see if that cures it first, if not then ul have to look at management or fitting the standard airbox to maybe get rid if the boost is creaping
What mods do you have? Was it cold?
Something as simple as a decat and exhaust will cause you to hit fuel cut even in summer. :lol:
Well theres your issue, it will always hesitate before hitting fuelcut so next time you get near take you foot off the throttle :p
  • 3 weeks later...
