i have a HKS actuator running 0.85 peak boost, full apexi system and HKS induction kit
is it safe to get a decat without getting mangement?
if so is it safe getting the intercooler or is that just a step to far?
Completely safe, you may get a bit of creep with the deact though, but the intercooler may also give more stable boost.
Below fuel cut you don't need any sort of fuelling or management, you may need to turn the actuator down a little or get a decent boost controller or even port the wastegate when you get the decat though.
ok thanks alot so buying plans should be decat, intercooler then management then turbo kit. or management and turbokit at same time
