Removing the gearbox help
Hi guys right im doing a clutch change lol, I've removed the driveshaft from the gearbox side and everything i cn see but the box wont seperate from the engine, i think I've got 7 long bolts removed, took off all the engine mounts, now when you jack up n down the whole engine moves with the box, so im stuck.. is there a guide anywhere on removing the gearbox?
cars a ep91 lol
  • 4 weeks later...
Look in the HOW TO section bud, as Enzo pointed out, i made a guide the other week luckily for you lol.
If youve removed the rear engine mount/drive shafts and front passanger side engine mount , jack the engine up so its level and assuming you have all the bolts removed holding the box onto the block, it should pull off with a bit of (gentle) persuasion :blink:
Craig.
