BAZ2CRAZY Posted November 2, 2008 Posted November 2, 2008 Will i run into problems when i fit these?Will resetting the ecu sort itself out?Is there any confirmation on the glanza s injectors being different?can the standard ecu be remapped?baz Quote
Rich Posted November 2, 2008 Posted November 2, 2008 will run lean but they may work well with a rrfpr or SAFC Quote
BAZ2CRAZY Posted November 2, 2008 Author Posted November 2, 2008 will run lean but they may work well with a rrfpr or SAFClean? wouldnt they be bigger?i thought itdbe rich if anything.How would a rrfpr sort this out?(just asking, not arguing ) Quote
Rich Posted November 2, 2008 Posted November 2, 2008 RRFPR Will increase the fuel pressure so more fuel. I think they run at a higher pressure than the normal ones so are rated at that if you get what I mean. Quote
BAZ2CRAZY Posted November 2, 2008 Author Posted November 2, 2008 i understand, would i need a 'mixture indicator' (forgot the proper name,wideband?) to set the rrfpr up?how sure are you that they will work correctly? also, noticable powergain from correctly setting them up?as i read somewhere that you didnt notice much difference? despite running lean Quote
Rich Posted November 2, 2008 Posted November 2, 2008 Well if their setup propperly and with other mods, you should see a bit of a gain I didn't notice a loss in power so their must be a gain somewhere. Quote
BAZ2CRAZY Posted November 4, 2008 Author Posted November 4, 2008 Well if their setup propperly and with other mods, you should see a bit of a gain I didn't notice a loss in power so their must be a gain somewhere.what other mods? Quote
RobSR Posted November 4, 2008 Posted November 4, 2008 theres no need for them...they are blatently smaller than the standard ones...so they have to run more fuel pressure...there is no gain in having them..as the standard ones setup properly will still not be anywhere near their max duty cycle. Quote
BAZ2CRAZY Posted November 4, 2008 Author Posted November 4, 2008 excellent, cheers rob. so would an fpr with standard injectors be beneficial? or a complete waste of time Quote
RobSR Posted November 5, 2008 Posted November 5, 2008 well you cant tell until you get the fuelling checked properly on an rr/ with a wideband....what have you actually done to the car which will make it need more fuel? if it is running lean anyway...either a safc or an adjustable FPR will be able to sort it out...would bother with those injectors Quote
ecksjay Posted November 5, 2008 Posted November 5, 2008 you will never notice a 'considerable' performance increase from tuning the n/a unfortunately. A slight increase perhaps, yes, but even those that have tried full standalone management on one (at great expensive) have struggled to eek much more out of the motor. Quote
RobSR Posted November 5, 2008 Posted November 5, 2008 thats why im not wasting money on mine...a safc that costs all of about 80 quid...and some throttle bodies that will cost about the same... Quote
ecksjay Posted November 5, 2008 Posted November 5, 2008 exactly, and even then you'll struggle to actually notice the difference in the real world, it just keeps you occupied until you can afford something with considerably more grunt/potential doesn't it, no point going all out with injectors etc and trying to tune everything to suit when there wont be a great deal of difference.Its your money, but people on here have tried it before obviously, so may aswell learn from that. Quote
BAZ2CRAZY Posted November 6, 2008 Author Posted November 6, 2008 exactly, and even then you'll struggle to actually notice the difference in the real world, it just keeps you occupied until you can afford something with considerably more grunt/potential doesn't it, no point going all out with injectors etc and trying to tune everything to suit when there wont be a great deal of difference.Its your money, but people on here have tried it before obviously, so may aswell learn from that.cheers lads, its exactly that really, just somthing to tinker with till the GT.i cant have a starbo and leave it looking like a grannymobile.il have a project page up soon.mitch. Quote
