Does anyone have a diagram of the ECU's on a glanza? Im told I have to connect a wire to the oxygen sensor just stuggling to find a diagram to figure out which pin it is.
Thanks in advance
  • 3 weeks later...
Mate, look at the diagran that Jay posted for you..
Its pin number 6 on the middle plug..
Im assuming you have bought a el cheapo air/fuel ratio gauge that only ever shows half the mix?
If youre running it off of youre o2 sensor you wont get a decent reading because a ) the sensor will be old and B ) the sensors not far enough from the turbo.
Buy a decent kit such as Innovate or AEM and they supply a boss that you weld into youre exhaust pipe, a new bosch sensor with all the correct plugs fitted.All you wil have to do is find an ignition on live and an earth to mount the gauge, and plug the sensor in.
The decent kits will show you the full scale of something like 10:1 all the way to about 18:1 which is what you want, unles you just want another gauge to show off..
