wchtim Posted November 13, 2008 Share Posted November 13, 2008 Hi everyone, I got my new glanza today and i have found some problem with my car. When i accelerate on gear 1 and 2, there is some click click.........../........./......... noise come out from the engine, but when I press the clutch, the wierd sound disappear. Anyone can help!!?? Hope DIY is ok to sort out the problems!! Quote Link to post Share on other sites
Idrees Posted November 13, 2008 Share Posted November 13, 2008 Sounds like the clutch release bearing to me, but I'm not too experienced on this stuff. Quote Link to post Share on other sites
Asad Posted November 13, 2008 Share Posted November 13, 2008 ^^^^ correcto release bearing seem to be common on EP`s....changed my clutch + bearing never heard it again. dont worry too much abt it only press it when you actually need it dont sit at the lights with the clutch at biting point so on n so forth Quote Link to post Share on other sites
tucka Posted November 13, 2008 Share Posted November 13, 2008 you got a boost conrtoller fitted? some Actuator valve controllers make a clickin sound, my apexi AVC SPEC D does! its def not your relase bearing! as stated it would only make the noise with clutch in Quote Link to post Share on other sites
ToddiGlanzaV Posted November 13, 2008 Share Posted November 13, 2008 Maybe the manifold gasket. Quote Link to post Share on other sites
StarletRick Posted November 13, 2008 Share Posted November 13, 2008 could be anything, youll have to be more specific. Quote Link to post Share on other sites
Asad Posted November 13, 2008 Share Posted November 13, 2008 hmmmm mine made the noise but went away when i pressed the clutch, after replacing i never heard it again...... Quote Link to post Share on other sites
Asad Posted November 13, 2008 Share Posted November 13, 2008 Is this the noise/something similar? try changing the oil to a synthetic one?http://uk.youtube.com/watch?v=gdVJ5vnO6Jg Quote Link to post Share on other sites
wchtim Posted November 15, 2008 Author Share Posted November 15, 2008 No, dont have boost gauge fitted!!No, that lexus can hear the noise when the clutch is release!!I mean, when my car on gear 1, maybe drive on 5-10 mph, then i can startr hearing the noise from the engine..And i hope not more further to the head gasket!!! you got a boost conrtoller fitted? some Actuator valve controllers make a clickin sound, my apexi AVC SPEC D does! its def not your relase bearing! as stated it would only make the noise with clutch inIs this the noise/something similar? try changing the oil to a synthetic one?http://uk.youtube.com/watch?v=gdVJ5vnO6Jg Quote Link to post Share on other sites
