Hi there i recently purchased a HKS Actuator and was wondering if someone could tell me if this method is correct to install to keep using the Glanza Dash Hi/Lo button.
In the kit comes with a little brass piece that reduces the diameter to 2.5mm, it looks like i install that in the P8 100mm hose and then connect to the T-piece. I know this is the pic for ep82 but it should be similar but just with different hose lengths for the ep91.
So is this correct do i insert the little brass reducer here??
Thanks
  • 2 weeks later...
