200sx-Starlet-Jay Posted November 25, 2008 Posted November 25, 2008 is the glanza clutch the same as the N/A one? like same shape and part number ect or are they different?Also what size is the standard glanza exhaust bore? Quote
kevink Posted November 26, 2008 Posted November 26, 2008 clutches are not the same, will ask someone for the toyotapartnumbers for you if you want.surely others will know this number to? Quote
Jozinobi Posted November 26, 2008 Posted November 26, 2008 is the glanza clutch the same as the N/A one? like same shape and part number ect or are they different?They are different sizes and are totally different part numbers.Also what size is the standard glanza exhaust bore?The standard glanza exhaust bore is 2"Joz Quote
200sx-Starlet-Jay Posted November 26, 2008 Author Posted November 26, 2008 my mechanic chum asked " how many splines are on the input shaft of a glanza gear box, the same as N/A or different?"Reason im askin is cuz when i drop in the fte i will be geting an Exedy clutch or sumthing similar, and need to get correct fittment.Cheers Quote
