JM_16v Posted November 27, 2008 Share Posted November 27, 2008 i assume they all work the same by lowering the voltage returned from the map sensor, so if thats the case then will an mr2 one work on the glanza Quote Link to post Share on other sites
Glanza_Ragger Posted November 29, 2008 Share Posted November 29, 2008 Ive got a theory..FCD's = BANGWhat are you using to up the fuelling past fuel cut if you were to fit one? Quote Link to post Share on other sites
