Dan Evans Posted November 30, 2008 Share Posted November 30, 2008 Hello all, I've just bought some gauges and billet sandwich plate, just wondering if anyone knows if it will fit, just seems to be abit limited for space, I've got to run an oil pressure and temperature gauge. if it does not fit is there another way of doing it, cheaply?????really need helpcheers Quote Link to post Share on other sites
WallaceGlanza Posted November 30, 2008 Share Posted November 30, 2008 Unless yu grind away the power steering bracket then no its won't fit, it may also foul the air filter piping.You can see how I fitted mine here:http://www.ukstarletclub.com/forums/index....mp;#entry209570 Quote Link to post Share on other sites
Dan Evans Posted November 30, 2008 Author Share Posted November 30, 2008 will i have to take it apart then?? is there any other ways of doing it?? Quote Link to post Share on other sites
WallaceGlanza Posted November 30, 2008 Share Posted November 30, 2008 A grinder is really the only other option, you can tee both the pressure and temp sensors into where the stock oil pressure switch connects to make it a bit easier. Quote Link to post Share on other sites
Dan Evans Posted November 30, 2008 Author Share Posted November 30, 2008 will i have to dismantel the car, as this is something i didnt want to do, when u say grind away the bracket have you got a picture of were you mean, as i dont want to grind away the wrong bit, sorry, new to glanzas Quote Link to post Share on other sites
Dan Evans Posted November 30, 2008 Author Share Posted November 30, 2008 or could you how me on a picture the standard oil pressure swith, i supose i could get an adapter to have the standard oil pressure and the gauge sensors together, just need to know were it is cheers mate Quote Link to post Share on other sites
WallaceGlanza Posted November 30, 2008 Share Posted November 30, 2008 Well if you still have the aircon in it will be an even bigger pain in the arse, if you don't have that in then you can get to the oil filter easily. When you go to fit the sandwich plate you'll see where you need to grind away the bracket and where it will foul the sandwich plate, depending on the sandwich plate you might be able to grind a bit off it which would be easier.This is a pic of someone else's car, you can see where they've grinded a bit of the sandwich plate, however its a small one to start with:Edit: You can see the standard oil pressure switch here:Its down on the right hand side of the block, however, again its hard to get off without having at least the downpipe removed. Quote Link to post Share on other sites
Dan Evans Posted November 30, 2008 Author Share Posted November 30, 2008 ahh i see, that would be betta if i could grind abit of the sandwich plate away, i do still have the aircon in aswell so i i think its gunna be a pain, would i have to dismantal the front end or could i do it without doing that?? cheers Quote Link to post Share on other sites
WallaceGlanza Posted November 30, 2008 Share Posted November 30, 2008 ahh i see, that would be betta if i could grind abit of the sandwich plate away, i do still have the aircon in aswell so i i think its gunna be a pain, would i have to dismantal the front end or could i do it without doing that?? cheersIts so long since I removed my aircon that I'm not sure! If you remove the engine splash guard you can get to the oil filter quite easily (with the car jacked up), but the aircon pump is right in the way too so it would probably need removed but I'm not entirely sure... Quote Link to post Share on other sites
Dan Evans Posted November 30, 2008 Author Share Posted November 30, 2008 ok, thank you for your help mate, il let you know how i get on, cheers bud Quote Link to post Share on other sites
