nerosis Posted December 15, 2008 Posted December 15, 2008 If i got a glanz with KM distance travelled and the speedo in Km, is it hard to change to Miles and how do i do it? and wht do i need? and how much does it cost? Quote
Newbe Posted December 15, 2008 Posted December 15, 2008 If i got a glanz with KM distance travelled and the speedo in Km, is it hard to change to Miles and how do i do it? and wht do i need? and how much does it cost?To change the speedo - http://cgi.ebay.co.uk/TOYOTA-STALET-GLANZA...%3A1|240%3A1318Not sure about distance travelled ive left mine in KmMatt Quote
nerosis Posted December 15, 2008 Author Posted December 15, 2008 To change the speedo - http://cgi.ebay.co.uk/TOYOTA-STALET-GLANZA...%3A1|240%3A1318Not sure about distance travelled ive left mine in KmMattis it just purely take off the old dial and fix this 1 in place? Quote
WallaceGlanza Posted December 15, 2008 Posted December 15, 2008 You can get a speedo converter off ebay for £35. That will mean the speedo will be in mph so you stick a sticker over the kph on your original dials, and the mileage will then count up in miles too, plus it derestricts the car (180kph limit as standard).They screw onto the gearbox by removing the cable then arewing the converter in betweeen. Quote
nerosis Posted December 15, 2008 Author Posted December 15, 2008 You can get a speedo converter off ebay for £35. That will mean the speedo will be in mph so you stick a sticker over the kph on your original dials, and the mileage will then count up in miles too, plus it derestricts the car (180kph limit as standard).They screw onto the gearbox by removing the cable then arewing the converter in betweeen.is this unit you speak of easy or hard to install? and does it come with distructions? Quote
WallaceGlanza Posted December 15, 2008 Posted December 15, 2008 Its a bit awkward, all you need is a big adjustable spanner to do it. But as standard the air box will be in the way to get easy access to where the speedo cable connects to the gearbox. Its easy enough aslong as the speedo cable nut isn't too tight, since its in an awkward place.Edit: It probably wouldn't come with starlet specific distructions or instructions for that matter. Quote
