Dan Evans Posted December 20, 2008 Posted December 20, 2008 hey, im after a wiring diagram for the steering colomn, trying to wire ma gauges, need to find the power, earth and the headlights.any ideas?? its a Glanza V 1996 Quote
ToyotaTech15 Posted December 20, 2008 Posted December 20, 2008 i wired my rev gauge without a diagram,if u take all the steering column plastics off to get to the wires, use a test lamp on the wires for the ignition barrel, there will be a permanent power feed to the ignition barrel.then find a wire that only comes live when you turn on the lights, this could take a while as im not sure how many wires there is. you can just take an earth from a near by body earth,either scotch lock all the wires on or solder them with heatshrinkGary Quote
