Hey, thought i`d take some pics etc when i was installing this "thing of purpose"....as you know the uk poverty spec N/A is just that, poverty ridden. Luckly we can nick bits off the glanza lads and customize :)
1) before picture a little smelly plastic square thing...
2) undo these two screws, and remove the trim by first lifting from the bottom (also remove the ashtray)
3) then undo these plastic clips on each side, by pushing them in from the back (they are located in the foot well area)
4) undo these two (under the piece of underneath the handbrake lever)
5) undo one of these on either side, where the rear ashtray is (move both front seats fully forward and jump in the back, much easier)
6) after pulling that panel out, things should look like this also take the gear knob off
7) Then your almost ready to pull the last panel out, remove the cigy lighter cable (has a push clip)
8) pull the panel out and remove these two screws
9) firstly on the right hand side loosen the top screw but remove the bottom one (so the bracket swings around) , and on the left hand side only remove the bottom one
10) bam! its out so you should have in your hand
11) when comparing the cup holders dont have the screw hole, not to worry they still fit perfectly
12) the cup holders should have these notch things bend them staright and they should line up and bend them over again so the holder is secure, after that its the reverse process
13) tedah! finished....(should have two remaining screws and the little smelly plastic square thing)
feel free to add/pm me with any questions also keep the plastic thing incase you sell up etc
