Ok ive brought a new car and all seems to be wired in ok :surrender:
Can any one tell me where the pipe of the back of it should be going to and does this unit run its own map sensor ??? Reason i ask is i have a second lambda sensor and cant seem to trail the wire back to see what it goes to and also i woould like to make sure its plumbed in right as it seems to do nothing when i change the boost setting...
Also does this unit remove boost cut ???
Or do i need a HKS FCD and wire it to the ecu wiring direct many thanks :surrender:
Any body all i need to know is where the pipe goes to i have a feeling it goes in the pipe between the actuator and turbo housing ? but if so should it have a one way valve or something i dunno but can someone help me out please:)
The pipe on the head unit unit will be for a boost reading and it will not have its own map sensor. Hope this helps :thumbsup:
Hi mate sorry to bug lol thanks for the reply do you have any instructions for the unit as for some reason my controlloer does naff all lol...
also there is a greddy map sensor under then bonnet but i cant find any Emanage ecu or anything???
Its steve b's old car the livesports one :p
should there be a second unit somewhere that actually adjusts the boost level as i dint think it could be done electronicly as such not without something to go in the pipe work i would have thought ?
