Thought as im bored il do a short tutorial on how to remove your center console on your dash, to change cd player etc, plus sparky was having a bit of trouble with him so i thought it do it for you all
First of all you need to remove the heater controls which just pull out
theres a plug behind...obviously
then there is 2 phillips head screws you have to remove
the trim will then pull forward and come loose
There then is 3 plugs to look at, unplug them
after these are unplugged the trim will come off
If you are removing headunit, youl have a cag e like this which is held in with 4 screws
pops out like this then
reverse all the following steps to fit together
by the way can a mod put this in the correct section please as i dont know where to put it on this site, thanks
