Liam_D Posted January 18, 2009 Posted January 18, 2009 Right i have came across the first problem with my car after drving it for just over a week!! Bascially everything was fine but coming back from a mates house last night my dash lights went off and wouldnt come back on. Thought nothing of it and went to check that all the wires/bulbs etc etc was ok. Took the dials out earlier and everything seemed fine so checked the lights again and everything was fine. :surrender: But just been out to warm my car up ready to go out to meet some friends and now i have no dash lights, front sidelights or any rear lights. :surrender: :surrender: All fuses and wires have been checked and nothing obvious is wrong with it. Has anyone else had this problem?? Or have any suggestions as to what the problem might be?? Any help will be appricated as it has put me in a really bad mood cuz now i cant use the car until the issue is sorted..Thanks in advance Liam Quote
Dan Evans Posted January 18, 2009 Posted January 18, 2009 you have got a loose connection, or the light relay is fooked. does it work every now and then or no lights at all? Quote
4efte_ryan Posted January 18, 2009 Posted January 18, 2009 i no you said that u have checked all of the fuses but i would double check the fuse inside the car sayin tail, this controlles side lights, tail lights dial lights just worth double checking thischeers ryan Quote
Liam_D Posted January 18, 2009 Author Posted January 18, 2009 Yeah yeah i was aware of the Tail Fuse controlling the only lights i havent got so i thought it was gonna be a easy fix. It started off only doing it every now and again but now its like a permanent thing and i have no lights at all. Quote
Liam_D Posted January 19, 2009 Author Posted January 19, 2009 This is all sorted now!!! Thanks for the help though people. Quote
