mckenzie Posted January 21, 2009 Posted January 21, 2009 Whats do the below do? putting a pipe from the standard dump valve to the engine? Any perks etc.Thanks Quote
Guest Enzo Posted January 21, 2009 Posted January 21, 2009 return for an oil breather, you can take it off and put a wee oil breather on there if you want Quote
BlackRocket Posted May 15, 2009 Posted May 15, 2009 thats my engine............ Not your car but just your engine!? ;) ;) Thought I recognised it from looking thru your pics tho!To answer the lads questionYou can either put an oil breather on there or hook it up to an oil catch canSteve Quote
Glanza_cl Posted May 15, 2009 Posted May 15, 2009 the above is fine if your wondering if you should change it, but yeah can put on a breather or connect up to a catch (if done properly) Quote
Dean @RW-Developments Posted May 16, 2009 Posted May 16, 2009 if you put a breather on remember to block off the efi, that you took the pipe off. Quote
Mart Posted May 16, 2009 Posted May 16, 2009 Your licence plate is in it too bro. Might be worth editing just incase... :surrender: Quote
