Hi Guys,
I've got a 4EFTE conversion loom which I had for my Paseo which i've now sold, my question is even though its a conversion loom designed for a 5EFE, will it work the same for 4EFE engined starlets? IIRC they're plug and play the 5EFE/4EFE engines bar ECU's but I want someone to confirm if it could be used?
The loom is going to be for sale and I was going to advertise in on here if the N/A boys can use it.
Cheers
I'd PM Joz on here (Jozinobi) as he's running a 5efe in his Starlet, so could tell you if a loom was needed to swap the engine, which should in turn answer your question :harhar:
