*Toymota* Posted May 6, 2006 Share Posted May 6, 2006 My EM light has started coming on intermittently.Looked thru this post http://www.ukstarletclub.com/forums/index....hl=engine+lightbut cant find the ecu diagnostic port in either the engine bay or under the driverside dash.Can anyone help me please Em Quote Link to post Share on other sites
starletboy Posted May 6, 2006 Share Posted May 6, 2006 should be where the air filter housing is it is a little box that says diagnoostic on it prob be be black on glanza's!!have you done the high low boost mod by any chance because that could have somethin to do with it does it come on when you boost it in 1st,2nd??? Quote Link to post Share on other sites
*Toymota* Posted May 6, 2006 Author Share Posted May 6, 2006 i have done the high low boost mod yeah. the problem is, my boost gauge covers the light an i only noticed it last night so i dont know how long its been on for haha.i did disconnect my speedo yesterday an havent reconnected it yet, could this be anything to do with it? Quote Link to post Share on other sites
starletboy Posted May 6, 2006 Share Posted May 6, 2006 ah yeah thats defo the problem does it only come on when you go on like dual carriageway etc where you go faster????and then when you turn it off and start again its out!?!?!? Quote Link to post Share on other sites
MisterAdam Posted May 6, 2006 Share Posted May 6, 2006 I'll show you where it is on monday if your going Quote Link to post Share on other sites
*Toymota* Posted May 6, 2006 Author Share Posted May 6, 2006 yeah, it only comes on wen im on a dual carriage way!found it now cheers adam, will see you monday though Quote Link to post Share on other sites
MisterAdam Posted May 6, 2006 Share Posted May 6, 2006 I'ev got the same problem, something to do with having a delimiter fitted im told See you an the other half on monday Quote Link to post Share on other sites
starletboy Posted May 6, 2006 Share Posted May 6, 2006 yep mine did same thing just took my convertor off and all good its just somethin they do when either speedo is disconnected or a dodgy convertor!!!! Quote Link to post Share on other sites
ecksjay Posted May 6, 2006 Share Posted May 6, 2006 the begininnings if fuel cut? mine comes on just before i hit fuel cut, but obviuosly means it was VERY close, so it may well have been that. Quote Link to post Share on other sites
*Toymota* Posted May 6, 2006 Author Share Posted May 6, 2006 Strange thing is when trying to do the ECU test for the codes when I put the paperclip in the EM light doesnt come on. I have checked the clip was in the right place.Does the light have to be on before you put the paper clip in?Also when the EM light is on the car idles around 1000rpm instead of 750rpm.Any ideas Em Quote Link to post Share on other sites
klyfax Posted May 7, 2006 Share Posted May 7, 2006 It becase the ECU goes to satety run, then the light are on... Quote Link to post Share on other sites
ben_j Posted May 7, 2006 Share Posted May 7, 2006 if it goes off when you turn the engine off and back on again. then comes back on when you put ya foot down hard. its the fuel cut isnt it? the engine is saying its underfueling. mine comes on when i boot it, but it doesnt matter as my piggyback ecu overrides and still fuels correctly Quote Link to post Share on other sites
*Toymota* Posted May 7, 2006 Author Share Posted May 7, 2006 im only runnin an exhuast an induction kit. boostin at between 0.7 - 0.8 barr. that not near fuel cut is it? plus it feels nippy an idles slightly higher occasionally when stopped? Quote Link to post Share on other sites
starletboy Posted May 7, 2006 Share Posted May 7, 2006 have you connected your speedo up yet because thats it try connecting it up again and dont start goin any deeper in to the problem till youve done that!!!!!! trust me im a toyota mechanic connect your speedo and go from there!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Quote Link to post Share on other sites
*Toymota* Posted May 7, 2006 Author Share Posted May 7, 2006 Ahhh didnt know you were a toymota mechanic, thats always useful hahaI havnt been arsed to connect it yet will do later lol Quote Link to post Share on other sites
starletboy Posted May 8, 2006 Share Posted May 8, 2006 yep everyone says that when they find out!!!!! but yeah connect it up and that will be it sorted im sure!?!?!? Quote Link to post Share on other sites
