bucketep91 Posted January 29, 2009 Posted January 29, 2009 hey lads just wondering if any1knows why the fans on my glanza dont come on / I've tried replacing the thermostat and the fans work when i put my air con on, this is the only way i can keep it cool... Quote
Dan Evans Posted January 29, 2009 Posted January 29, 2009 hey lads just wondering if any1knows why the fans on my glanza dont come on / I've tried replacing the thermostat and the fans work when i put my air con on, this is the only way i can keep it cool...by any chance have you removed your air con?? Quote
bucketep91 Posted January 29, 2009 Author Posted January 29, 2009 by any chance have you removed your air con??no :-S my air con is the only thing that keeps the car cool Quote
Dan Evans Posted January 29, 2009 Posted January 29, 2009 no :-S my air con is the only thing that keeps the car coolcheck the connections for the fans, if there connected it could be the fan motor itself. Quote
bucketep91 Posted January 29, 2009 Author Posted January 29, 2009 check the connections for the fans, if there connected it could be the fan motor itself.but the fan comes on when the aircon is on:-> lol Quote
AntEP82 Posted January 29, 2009 Posted January 29, 2009 have you checked your fuses? I had the same problem and i had a blown fuse, as soon as i replaced it, the fan worked fine Quote
bucketep91 Posted January 29, 2009 Author Posted January 29, 2009 have you checked your fuses? I had the same problem and i had a blown fuse, as soon as i replaced it, the fan worked finewell actually lol i feel quite silly now but ermm no:)) ill give it a try 2morro thanks mate lol Quote
AntEP82 Posted January 30, 2009 Posted January 30, 2009 no worries! Yea luckily it was the first thing i checked when my coolant overflowed everywhere when it was just sitting idling lol but yea fan worked fine after that so fingers crossed it's just that mate. Let us know the verdict Quote
Starletraje Posted January 30, 2009 Posted January 30, 2009 if its not the fuse you should test the thermostat.take it out, tie it to a bit of string and submerge is in boiling water. lift it out and check to see if it has opened. if it has its fine, if its still closed you need to replace it Quote
paul w Posted January 30, 2009 Posted January 30, 2009 The air con fans are seperate to the main fans iirc.Have you cleaned the rad? Got enough/any coolant in there? Quote
