iamlegend Posted February 1, 2009 Posted February 1, 2009 this will be for a GT 1995? ^^^^andwhat HT leads : Magnecor Ignition LeadsEP82 8mm Clip Type ?EP82 8.5mm Clip Type?EP82 8.5mm Boot Type ? EP82 8mm Boot Type? Quote
tucka Posted February 1, 2009 Posted February 1, 2009 this will be for a GT 1995? ^^^^andwhat HT leads : Magnecor Ignition LeadsEP82 8mm Clip Type ?EP82 8.5mm Clip Type?EP82 8.5mm Boot Type ? EP82 8mm Boot Type? im runnin clip type on mine, heat range 7 i think, pendin on how modded your engine is ectbut i dont know if the 82 is any diffrent from the 91 Quote
paul w Posted February 1, 2009 Posted February 1, 2009 Heat range 7 for standard/lightly moddedThe leads will be clip i believe, look at the ones you already have on the dizzy cap. I used 8mm on mine but it really makes no difference which you use. Quote
