kevink Posted February 2, 2009 Posted February 2, 2009 Hi guys & gals,cause my Glanza came out of the UK it still has a MPH reading. can someone tell me where the lil convertor is so i get take it out?next question is how to remove the convertor, something special i have to look out for?Thanks in advance!Kevin Quote
garbla900 Posted February 2, 2009 Posted February 2, 2009 it was already here and you exported it? if you go to the gearbox side of thing and lift out the air filter or induction kit which ever is ther and look at the gear box you will see the speedo cable sticking in to a smalll black box. it just unscrews of the top and then there is a small collar on the bottom of the unit that unscrews. you just remove the unit and then the speddo just screws in to the gearbox and that will put it back to the kph readings. hope this helps if you need anything else pm me. Quote
