raymond Posted May 7, 2006 Posted May 7, 2006 Hi all, seem 2 have a knocking noise soming from my glanza, at first it sounded as if it was coming from the back but know it may be the front, seems to knock when going over a bump in a corner, doesnt seem to bad going over bumps on straight bit of road, looked at springs, shockies, drop links, trailin arm bushes, all seem fine.Thought it may be poss engine mount.Any help appreciated Quote
Shaun Posted May 7, 2006 Posted May 7, 2006 maybe top mounts mate try that just go over ever joint and cheak for playmate Quote
james gtt Posted May 9, 2006 Posted May 9, 2006 Hi all, seem 2 have a knocking noise soming from my glanza, at first it sounded as if it was coming from the back but know it may be the front, seems to knock when going over a bump in a corner, doesnt seem to bad going over bumps on straight bit of road, looked at springs, shockies, drop links, trailin arm bushes, all seem fine.Thought it may be poss engine mount.Any help appreciated<{POST_SNAPBACK}>i,d say may be a cv joint if its when your going round corners Quote
raymond Posted May 11, 2006 Author Posted May 11, 2006 i have standard suspension, dont think its the exhaust, noise is like a clunkinig noise so think it is somethin takin alot of wheight like engine mount, top mount????startin 2 do my head in a little Quote
paulgtt Posted May 12, 2006 Posted May 12, 2006 had similar problem on my gt....split driveshaft gaiters. Quote
starletno1fan Posted May 16, 2006 Posted May 16, 2006 im thinking cv joints aswell. wheel bearing? Quote
klyfax Posted May 21, 2006 Posted May 21, 2006 I haved this problem on my kadett. It was the topmount at the front suspension. Where you set your tower bars. Quote
