turbodreams Posted February 7, 2009 Posted February 7, 2009 hello folks, i need a whole new suspension kit, but i dont want to spend to much money to be honest, whats a good kit, that will serve me well on scottish shitty roads but doesnt burst the bank? Quote
gotboost? Posted February 10, 2009 Posted February 10, 2009 The best thing to do in your case would be to just get some new (possibly uprated) shocks and some lower springs. That would be the first step..Then you could always go on and add:- Front Strutbrace (stops chassis flexing and makes the car feel a little more solid + flatter around corners)- Rear Strutbrace (similar effect)- Urethane bushes (no doubt the rubber ones would have worn out by now)and so on...There's always the option of coilovers but I think you're going to find that they're a little too solid for "shitty scottish roads" lol Quote
Tintin_SR Posted February 10, 2009 Posted February 10, 2009 The best thing to do in your case would be to just get some new (possibly uprated) shocks and some lower springs. That would be the first step..Then you could always go on and add:- Front Strutbrace (stops chassis flexing and makes the car feel a little more solid + flatter around corners)- Rear Strutbrace (similar effect)- Urethane bushes (no doubt the rubber ones would have worn out by now)and so on...There's always the option of coilovers but I think you're going to find that they're a little too solid for "shitty scottish roads" loljust tuffen up a bit and get coilovers its not as bas as you think its going to be Quote
gotboost? Posted February 10, 2009 Posted February 10, 2009 I was thinking the exact same thing I just thought I'd suggest the other options first though, as i don't know how bad the roads are over there. Quote
Guest Enzo Posted February 10, 2009 Posted February 10, 2009 on my silver daily i used the standard shock and spring setup along with one of my own anti lift kit and rear arb, the best of both worlds,greatly improved handlling and the added advantage of a nice supple ride.but if i were to recoemend a good cheap kit it might be worth condering trying out g-maxes shock and spring kit at £370 Quote
mel Posted February 11, 2009 Posted February 11, 2009 on my silver daily i used the standard shock and spring setup along with one of my own anti lift kit and rear arb, the best of both worlds,greatly improved handlling and the added advantage of a nice supple ride.but if i were to recoemend a good cheap kit it might be worth condering trying out g-maxes shock and spring kit at £370Will the GMAX suspension kit fit a glanza v? rang some shops about this kit and said does not fit the glanza UK specification only Quote
Tintin_SR Posted February 11, 2009 Posted February 11, 2009 Will the GMAX suspension kit fit a glanza v? rang some shops about this kit and said does not fit the glanza UK specification only if it fits the uk then it will fit the V as thy are the same car with a different engine, well sortof Quote
mel Posted February 11, 2009 Posted February 11, 2009 is this for defo 100% fits the glanza v. Anyone else know of this gmax suspension kit that will fit cheers. Quote
