got a problem guys wondering if anyone knew what could be wrong?
boost is kicking in no problem as normal bt as i start to get up the revs the boost seems to drop off, i dont have a boost guage so dont know wats going on :-S then if i keep the foot down i geta big missfire then the engine light comes on
any ideas?
The missfire and engine light comming on defo sound like your hitting fuel cut. You decated or removed the EFi pipe recently?
last thing i had done was the decat. been ever since then but seems to be getting worse, what is the efi pipe?
Yup deffo hitting fuel cut, the decat is causing the problem
Ideally you need a HKS actuator (holds boost better) and a boost controller of some sort.
The EFI pipe is the pipe that goes to the airbox (top right hand side of the engine bay)
thanks lads:D
that givesme an excuse to buy some new bits lol :) in the mean time if i take the lead boots off will the car be ok to drive without causing any damage?
It will be fine try resetting the ecu and it should run a bit better, if you got a boost gauge just keep an eye on the boost and back off before the cut :)
reseted the ecu. will leave it running for 10nthen try it out. ill let you know how i got on. thanks:D
what damage does fuel cut actually do:-?
Yea sounds just like the problem i had.. Mine didnt even need a decat to hit fuel cut.. just bypassing the solenoid did it for me.
As sparky said, new adjustable actuator and/or rrpfr and FCD should solve it :)
resetng the ecu worked for a while but now the problem is back my boost guage just came through and i fitted it and it shows im boosting to just under a bar, im using the standard actuator wwith no boost controller why is it so high? and what can i do to sort this?
