Is it possible to replace just the CV joints or will I need the complete shaft and joints??
Also will my Driveshaft fit off my n/a or are there different number of splines on the GT with ABS??
Cheers Lewis
The joint is replaceable as for weather the N/A one will fit or not i dont know but i assume the abs one has the "ring" around it for the sensor.
Changed both outer cv joints on my glanza can have with or without abs mine was with and 23 or 30 inner splines depending on what the drive shaft has!! easy to do did both on my drive!! :D oh and pretty sure n/a shafts wont fit gt but still pick a joint up for bout 45 to your door!!
its the ABS ring you gotta watch out for, therefor a n/a shaft won't just fit easy.
RicoW had a right nightmare getting a propper one..
