starlet virgin Posted February 11, 2009 Posted February 11, 2009 hi there been noticing that when im changing gear normally 3 to 4th if im giving it some speed on the gear change gives a really loud like pop bang and sometime a flame out the exhaust any one have a idea what is causing this and is it any think to worry about many thanks Quote
Glanza_cl Posted February 11, 2009 Posted February 11, 2009 do you get a jult before it happens could be fuel cut?what is the spec on your car? it could only be popping flames if you are running rather rich Quote
ChineseMafia Posted February 11, 2009 Posted February 11, 2009 Same thing is happening to me and i think for sure im running rich i can smell the gas in the fumes. Quote
starlet virgin Posted February 12, 2009 Author Posted February 12, 2009 do you get a jult before it happens could be fuel cut?what is the spec on your car? it could only be popping flames if you are running rather richits a 1996 with bailys dump valve hks exhaust and indution kit running pretty stock Quote
Glanza_cl Posted February 12, 2009 Posted February 12, 2009 then it shouldn't really pop flames, the only reason i know of it fuel cut that's when the car goes over it's stock boost level around 0.85and for safety reasons fuel cuts happens, this will result in a big jerk then sometimes a backfire or flames as there is unburnt fuel in the exhaust.if you don't already get a boost gauge, then see what you are boosting at before it happens and report back. Quote
starlet virgin Posted February 12, 2009 Author Posted February 12, 2009 then it shouldn't really pop flames, the only reason i know of it fuel cut that's when the car goes over it's stock boost level around 0.85and for safety reasons fuel cuts happens, this will result in a big jerk then sometimes a backfire or flames as there is unburnt fuel in the exhaust.if you don't already get a boost gauge, then see what you are boosting at before it happens and report back.thats sounds right im gonna invest in a boast controller and in the mean time will just drive softer cheers mate Quote
Tintin_SR Posted February 12, 2009 Posted February 12, 2009 try reeving it up not in gear to near the top then half throttle it as it comes down the rev see what it dus,myn ust to do to that and it was one of the wires going in to the ICV simple fix Quote
