paz46 Posted February 22, 2009 Posted February 22, 2009 hi I've got a sr (now a turbo) and I've got a rear axle from a gt on but standerd front brakes i want to upgrade them wot do i need to fit glanza brakes on the front thanks alot Quote
Guest Enzo Posted February 23, 2009 Posted February 23, 2009 glanza discs, pads and calipers is all you would need its a straight swap. but im thinking that sr brakes are actualy the same as glanza ones at 256?? mms and vented Quote
Tintin_SR Posted February 23, 2009 Posted February 23, 2009 watch though as i got at set of nice shiny 3g dicks that ware meant to fit my car and thy nerve did there to big for the sr calipers not happy face Quote
paz46 Posted February 23, 2009 Author Posted February 23, 2009 ok after a bit ov poking around on net I've found out the sr front disk is 254mm x 18mm and the glanza is 255MM X 22MM thanks for your help lads Quote
RobSR Posted February 24, 2009 Posted February 24, 2009 are they defo no different then g? as mine look like bottle tops Quote
