p15tle Posted February 22, 2009 Posted February 22, 2009 if which my car is limited to 112 :drunk2: is it easy to remove?and what do i need to do to do it? :surrender: any help/info much appreciated cheers guys Quote
WallaceGlanza Posted February 22, 2009 Posted February 22, 2009 An sld (speed limit defencer) or speedo converter is the way to do it, simple. Quote
Dave@TM-Developments.com Posted February 22, 2009 Posted February 22, 2009 http://www.tm-developments.com/index.php?m...;products_id=10 Quote
Glanza_cl Posted February 22, 2009 Posted February 22, 2009 just get a mph converter and that will delimit it and convert from kph to mph Quote
p15tle Posted February 22, 2009 Author Posted February 22, 2009 cheers guys tip top service as usual Quote
Philm Posted February 22, 2009 Posted February 22, 2009 when running more than 180bhpish there limiter can sometimes(all the time) allow you straight through, no issues.few guys told me this and i have found this too.Phil Quote
p15tle Posted February 22, 2009 Author Posted February 22, 2009 i was looking at getting a jam or blitz ecu to get rid of limit, feul cut ect ect i have an uprated actutor and was going to use a ebc aswell.then im not sure if i should go FCD and rrfpr, ive read alot of people dont really like using a FCD tho so im proper puzzeld as what is the best way to go .any help or better suggestions much appreciated cheers Quote
Glanza_cl Posted February 22, 2009 Posted February 22, 2009 there are so many threads on it buddy just do a search...basically you can do either if set up PROPERLY there is nothing wrong with a fcd and rrfpr but there's only so much you can do with a fcd as a ecu you obviously have alot more adjust ability.just have a poke around in the tech section Quote
