martin_2069 Posted May 16, 2006 Posted May 16, 2006 Hey to every 1 wid a carb engine. this guy i know has an old mini. wen he revs it and turns the key off and on while its revving quite high it shoots flames out the exhaust. he says its cause its a carb. i tryed and it poped once but no flames. wats up wid that. Quote
scutch0 Posted May 16, 2006 Posted May 16, 2006 yeah, thats just simple back firing... most just go bang... it must be overfueling by loads and have a really hot exhaust to make it spit flames, or hes got a popper in the exhaust or the ignition is retarded loads!Rich. Quote
BlackTarw Posted May 16, 2006 Posted May 16, 2006 wid? ah "with"...I think I understand what you've written I think flames out your exhaust is usually a result of very high lift cams (or anti-lag on a turbo) my old mini used to do it when lifting off quickly at high revs, looked cool, sounded better popping and farting on the over-run. I'm guessing that there's a lot of unburnt fuel which ignites in the hot exhaust manifold. Not sure if you'd want to replicate it on a modern starlet though as it'd probably fry your cat...you could get yourself a flamer kit, but those look crap Quote
BlackTarw Posted May 16, 2006 Posted May 16, 2006 yeah, thats just simple back firing... most just go bang... it must be overfueling by loads and have a really hot exhaust to make it spit flames, or hes got a popper in the exhaust or the ignition is retarded loads!Rich.<{POST_SNAPBACK}>Yeah once I got it on the rolling-road it calmed down a lot, made an extra 15bhp at the wheels and was better on juice too. Quote
klyfax Posted May 16, 2006 Posted May 16, 2006 I have a mate that have a mini racer, and it makes flames between shifts. Look nice, sounds nice... Quote
Shaun Posted May 16, 2006 Posted May 16, 2006 dont do it on the starlet with turn on and off the ignition as the cam belt might snap and you will fuck your ecu up Quote
nathy boy Posted May 16, 2006 Posted May 16, 2006 my 106 can do that spits out flames. . its okay until something goes wrong suppose people i know blown manifolds and stuff doing it Quote
Shaun Posted May 16, 2006 Posted May 16, 2006 just do it to some one else car like when your at work lol Quote
scutch0 Posted May 16, 2006 Posted May 16, 2006 dont do it on the starlet with turn on and off the ignition as the cam belt might snap and you will fuck your ecu up<{POST_SNAPBACK}>he has a carb one mate so he has no ecu Quote
klyfax Posted May 16, 2006 Posted May 16, 2006 Full speed on a carb. Active chocker (if its have one) Turn off igition, wait until its down on 1k rpms then turn igition on. A good trick to scary olds ladys!!!! Quote
Ryno Posted May 16, 2006 Posted May 16, 2006 haha, remember the carb trick from when i first started driving, ignition off, few pumps on the gas and the fire her back up!but please no one try it on there GT/Glanza! Quote
Blue Icarian Wings Posted May 17, 2006 Posted May 17, 2006 Or make your own kit,.......FIRE!!!!!!!!! Quote
