peternc Posted May 17, 2006 Posted May 17, 2006 hi..i am having trouble starting my starlet.i had left the sidelights on and battery went flat.so i removed the battery and charged it up.after putting it back on i cant start it.does removing the battery cause probs?.i would b grateful 4 any advice.....cheers peter,newcastle.uk. Quote
klyfax Posted May 17, 2006 Posted May 17, 2006 hi..i am having trouble starting my starlet.i had left the sidelights on and battery went flat.so i removed the battery and charged it up.after putting it back on i cant start it.does removing the battery cause probs?.i would b grateful 4 any advice.....cheers peter,newcastle.uk. <{POST_SNAPBACK}>Does the starter do anything? Do you have igition on? Other cars needs to boost the fuel pump, if the car has been out of power for a while. I don't know if thats the case for a Toyota... Quote
peternc Posted May 17, 2006 Author Posted May 17, 2006 Does the starter do anything? Do you have igition on? Other cars needs to boost the fuel pump, if the car has been out of power for a while. I don't know if thats the case for a Toyota...<{POST_SNAPBACK}>yes starter does turn ok and ign ok cheers Quote
warde Posted June 1, 2006 Posted June 1, 2006 yes starter does turn ok and ign ok cheers<{POST_SNAPBACK}>pull the fuel pipe off under the bonnet that feed fuel to the engine and place into a clear bottle and turn ignition on if fuel come out the pump is prime if not the pump will need to be primed some how to enable fuel to reach the engine Quote
lobotomy Posted June 1, 2006 Posted June 1, 2006 Because you've run the bettery totally flat you may need to replace the battery altogether.This is because running a bat flat can affect its CCA (cold cranking ampage) - The ability of the battery to turn the starter. Quote
lobotomy Posted June 1, 2006 Posted June 1, 2006 Sorry read through again... take it the starter turns ok with the current bat?Check fuel is getting to the engine by the above method. Quote
BlackTarw Posted June 2, 2006 Posted June 2, 2006 my mate had one of those in uni, went like stink, cracking engine on it, even with 6 of us in it Quote
