Hi, i am building a glanza from a n/a and i have swapped the rear axel over to rear discs etc. I need to know where or what direction these 6 wires head in? They travel from the ABS unit under the steering-wheel and down under the drivers side sill cover and head towards the rear. My loom was cut half-way as i got a front-cut.
I believe the twisted pairs go to the sensors on each side but unsure where the others should be correctly terminated.
The abs plugs enter the floor pan in front of the rear wheels and on the vertical part infront of the rear seats.
So does anyone have there glanza stripped at the moment or next time you take your sill cover off to tell me where the wires shoot off to.
Thanks
Thanks
