STEVO9000 Posted March 26, 2009 Posted March 26, 2009 There any walkthroughs for fitting front braided lines?Got some for my Paseo I want to fit.Quick question aswell, can the rear drums be bled, if so, how? I'm assuming I'll need to bleed them as well if I'm draining the system of fluid and replacing it with DOT 5.1Also, whats the best way to drain the fluid? lolThank yoooooooooooou Quote
Asad Posted March 26, 2009 Posted March 26, 2009 Hey bud how to for the lineshttp://www.ukstarletclub.com/forums/index.php?showtopic=2591the rear can be bled, there is a nipple on the rear of the drum.....bleeding the system you have to start with the wheel furthest away i think? not sure which is the best way to drain all the fluid tbh never done it. Quote
